Correct Wiring harness
FreightTrain
Banned
2,730
13
Gadsden,Al
Who has the correct wiring harnesses for a M35A2 multifuel with turnsignals and Alternator?Front and rear.I can live wth a M36 and just loop it in the middle.I see some on ebay right now.$345 for front and rear.But I know that one guy is laying out his butt selling M35 harnesses as M35A2.I fell for it and bought one a few years ago.I am gonna start removing sheetmetal from my original deuce so I can do a full back yard frame off.
Floridianson
2,525
Interlachen Fl.
Kenny think you saw up close the winch truck. I'm going to say it but should have left this one to rust out in Jax. The winch is spoken for and Allen said he might know someone that is looking for front and one rear axle. The bed and the cab I guess I will scrap as more rust than paint. I need the battery box and tool box with hangers. That leaves one axle, trans. and air shift transfer. I all ready grabbed the starter off the motor for the other soft top truck when the starter gear exploded right after we got it home. So the motor I guess I will keep as it look like it might have a few parts left that I could use in the future.
jatonka
94
Ephratah, New York
M35A2 wiring harness
Dave Walker at Walker Auto in Hesperia California sells them all the while on Ebay. He ships Fast and is reasonable. he has Multifuel and gasser harnesses and He knows the difference. I have bought many of them from him over the years and It is always the right deal. John T
devilman96
17
Boca Raton, FL
RE: M35A2 wiring harness
It would come close to working but would be to short across the front of the truck... Memphis should have them as they make their own harnesses, not cheap but new stuff for old trucks never is.
1,158
hndrsonj
Senior Chief/Moderator
376
Cheyenne, WY
Clinto, try Antelope Valley. They had them reasonable a couple years ago.
kbush
Alamosa, CO
I bought one from the guy John suggested on ebay and I think its the wrong harness. It has the connector for the old regulator that was mounted on the firewall and where the connector for the flasher box is supposed to be looks like just a bunch of ground wires. 7 or 8 of them I think.
I don't know what I'm supposed to do with those.
I am having the same turn signal trouble a lot of others describe in other threads. The odd thing about it is they DO work if only I have the light switch in the cab in certain positions. The left front and rear turn signals always work. Right front and rear only work if dash lights are on and in black out marker or black out drive.
David_Clements_4x4
Missouri
the links to OD Iron are dead ends again, is the harness on saturn surplus PN: 11677081, NSN: 2590010163187 the correct harness for M35A2
or if someone can tell me where to find the right one for an m35a2 i would appreciate it, my harness is starting to crumble in places
EDIT
after lookin a little more found the new links to OD Iron
http://www.odiron.com/store/product_info.php?products_id=650 Main
still couldnt find rear harness
tco3129
Flat Top W.V.
I just received the front, rear, and dash wireing from ERIKS MILITARY SURPLUS. Have not installed yet due to weather. Don't know if there will be any problems.
