Couple of interesting things....
Rapracing
Western Pennsylvania
I got the urge to go out this evening and start the generators. I has been a couple of months since they were last started.
I had an overcharge issue with my 002. It would creep into the red in 5 to 10 minutes of running. Just ran it for about 45 with 50% load and it never went above the center of the green on the meter. I didn't think to check it with a VM. it had been running over 30 volts but the meter was buried in the red.
Could it have corrected itself? Any thoughts?
My 003 would smoke white from the one exhaust for several minutes after starting it. Tonight when I started it there was white smoke for maybe 10 seconds and then it cleared. Wondering if an injector may have freed up?
Any thoughts?
cuad4u
89
St Matthews, SC
I bought a 002A off Craigs List real cheap a few weeks ago. It was missing some major parts. After replacing them it started right up and generates properly. Only problem is the 28V battery charging circuit puts out 30.5V with the batteries connected after 5-10 minutes just like yours. I replaced the 28V regulator with another one and same thing. I checked grounds and connections. I still get 30.5V from both regulators. I guess I have two bad ones.
CDR
new york
I noticed they tend to over charge when you have one battery that is either shot or discharged more then the othet
glassk
Hampton, GA
(b) With the stator leads (1) disconnected,
check voltage across two leads (1) from stator. Voltage
should be in a range of 30-35 volts AC with the engine
operating normally at 1800 RPM, If voltage is less than
30 volts AC, stator on magnets in rotor maybe defective.
Refer to higher level of maintenance for
b. Battery Charging Regulator/Rectifier Assembly
(see figure 4-23).
(1) Inspect. Inspect regulator/rectifier assembly
(5) for physical damage. Check that leads from
assembly to terminal block (3) are not damaged or
frayed. Check that assembly is securely mounted to
engine back plate (4).
(2) Test.
(a) Test stator as given In paragraph
4-27a above to see that it is operating correctly.
(b) Remove fuse (9, figure 4-23) and connect
a 10 amp ammeter across the fuse holder
terminals as shown in figure 4–24. With engine operating
normally at 1800 RPM, charge rate should be no
less than 6.5 amps when loaded by a discharged battery.
Charge rate should taper-off as battery becomes
charged.
TM 5-6115-584-12
Rapracing
Both brand new batteries last fall
At Glassk: I was going to go through the process of checking the DC voltage but was wondering if it is possible that it corrected itself. I will need to start it again and put the meter on it as see what I am getting to be sure but the DC gauge was right i the middle of green
Keith_J
1,327
Schertz TX
Check frame bonding straps, replacing star tooth washers. Aluminum oxide is an insulator plus Al loves to corrode.
CRV
FOREST HILL,MARYLAND
White smoke usually means too much air and not enough fuel, injector was probley sticking and then started working i have used a little atf in my diesel fuel in my pickup and over the road truck and my generator i have had good luck dueing this helps give the low sulpher a little more lubrication power. Pickup was blowing white smoke and this cured it.
rustystud
3,277
Woodinville, Washington
I have to disagree here, over time 30+ volts out of the charging system will cook batteries
It depends on what batteries your using. All our busses are now using the "Odyssey" extreme batteries. The charging voltage for them is 29.3V to 30.0V . We had to get special regulators and battery chargers.
Jeepsinker
467
Dry Creek, Louisiana
No it won't. At + or - 10% tolerance on 28 volts at charge that is 2.8 volts, which allows for a maximum safe charging voltage of 30.8 volts on conventional batteries. Ever take any electronics courses? And don't get mad here, I'm not trying to belittle you or be nasty.
Rapracing
I'm not going to argue or debate for that matter but when it was charging at 30 - 30.2 it did seem to be boiling/foaming. When i took the battery covers off it was a bit white and foamy looking. I'd tend to think as many on here you are loosing liquid if charging too fast/hard
Ratch
Chester County, PA
If you're concerned, you could buy a 24v battery charger and plug it into the convenience outlet. That's what I did when my charging circuit on my 002 failed.
Rapracing
I'm not concerned. I was just curious if it may have corrected itself. It always showed in the red before but was in the middle of the green on the gauge. I know, the gauge could be messed up and I never gave it a thought to check it with my multimeter when it was running. May start it up again later this afternoon and let it run for a bit and check the voltage with the multimeter.
rustystud
3,277
Your right. When the batteries are charged hard they will loose water faster. The batteries I was referring to are AGM style batteries, so no water loss.
Jeepsinker
467
Also keep in mind that the charging system will charge low batteries harder until they come up to acceptable levels, then the regulator will tell the system to slack off once the batteries come up.
