deercoker
- 19
- 8
- jonesborough/Tennessee
I need help! The police dept had done a scalp job on the 12 conversion on my 85 1009, so I decided to try and at least do the roscommon conv. opting for only 1 alternator, I had a very reputable auto electric shop rebuild it and installed it according to the roscommen equip.directions and everything has been fine for about 2 weeks, since I bought the blazer the voltmeter of course does not work on 12 volt so I installed autozone 12volt in its place in the dash, dash voltmeter readings were between just a little above 14 volts with engine running, I confirmed this with my digital voltmeter at the batteries and was getting about 14.3, for the last few days now my dash voltmeter jumps from over 14 to over 15 volts, at the batteries I get 14.4 to 15.6 volts back and forth, I had the alternator retested at the electric shop and could not duplicate the high readings, I reinstalled it and redid the grounds to the engine and then to the body, did fine for about 30 minutes of running the started the high readings again and noticed the dash lights and headlights would dim and brighten continuously, I have a new belt installed and is tightened properly, any suggestions? could it be that I grounded the alternator to the engine to body but bypassed the frame?
