2deuce
- 182
- 63
- portland, oregon
There are a number of reasons an alternator will stop charging. I was wondering if others that rebuilt their alternator and knew which part failed and the symptoms it displayed before it totally failed. I have had the dash light give off a dull glow that seemed to gain in brightness until it failed and I have had the dash light flicker at higher RPM's that when I applied a draw like headlights or the blower fan would stop flickering. I usually run with the lights on all the time for this reason. I'm thinking this alt may be on it's last legs.
I have seen rebuild kits for sale but I would like to replace only the faulty part. I took one of my bad alternators apart and everything checked out fine. The only thing I couldn't check was the regulator. Is there such a thing as a common failure? or at least one problem part that fails a higher % of the time? maybe the regulator?
Lastly I dug out another bad alternator opened it up and it was built with a different configuration and part from the rectifier to the regulator. Not all CUCV alternators are the same.
Thanks
Thanks
