Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
well I believe i am truly cursed... updated the starter relay (doghead upgrade) only to find 10.3 V on the purple wire at the starter solenoid. so I go to check and clean/ or replace the purple feed in the bulkhead connector. only to have the bolt holding it together snap off!!!!!!!!!!!!!!!!!!!!!!!
so now i cannot get it apart grrrrrrrrrrrrrrrrrrrrrr
So i ran a new 14ga lead from the new starter relay/ solenoid (thankfully i have a hole in the firewall to pass the low controller through) and connect it to the Solenoid and she turns... Now I can see how truly bad my batteries have gotten from not being charged properly... Time to buy Batteries...
since i have had my fill of wiring issues in the freezing cold.. Im goin to make a semi permanent purple bypass wire and call it a day..... I will mess with the firewall pass thru in the spring when its warm... i dont want to pry on the engine side plug in the cold.... with luck there will be enough of the bolt left to remove it.
And start a new thread, telling us about yourself. What your skill set is and then what type of vehicle you have. While we can make alot of guesses we are not mind readers....
Also trying to use capital letters and punctuation is a requirement when posting.
thanks man.... your assistance was appreciated and very helpful.... like i said in the warmer weather ill try to replace the purple starter wire... for now shes working.... ready for work....
we are in single digits and blustery winds for the week.... up here in the salt box salt damage is insidious...
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
