CUCV light switch
rfischba1
Fort Meade MD
Tried to turn my lights on my M1009 while the truck was ideling, nothing?
How does the black out/service light switch operate, the manual say pull it out and up? I did not pull it out only filpped it to on for service lights, then pulled out head light switch, nothing, I hope I was doing something wrong and its not a major electrical problem, Truck runs smooth, batteries are strong.
Any suggestions?
Crash_AF
Colorado Springs, CO
It should not move up unless you pull the switch out to disengage the lock. Pull out the right hand B/O light switch and move it up. It should stay in the up position. Then check your lights. You can turn a turn signal on so that when the switch works, the signal will start to flash.
Later,
Joe
rfischba1
Fort Meade MD
That shounds like this problem, I did not correctly flip the right swithes, I didn't pull out , and did not touch the BO drive switch. I'll try your suggestion and let you know how I made out, Very unlikely all lights are inoperable.
