coecamo
- 0
- 6
- Canton Mich
Has anyone installed a reciever hitch on a M1008? If so what brand or hitch number? With the tow shackle brackets on the frame mounting could be complicated. Gary 86 M1008
These will bolt right under your bumper...$24.00
- Harbor Freight Tools - Quality Tools at the Lowest Prices
Yes, the Blazer's do use a different hitch than the pickups do. The width between the frame rails is the problem. The Blazer's frame rails are closer together.Blazer uses a different hitch than a pickup. I believe the blazer hitch is tougher to install because between the pintle brackets and gas tank, it's almost impossible to get the bolts in and tightened. Think you almost have to drop the tank to get it done. Or weld it on.If the trailer height is high anyway, you might just get a combo ball/pintle hitch and bolt it on where the pintle bolts. Might be easy to make something that uses the stock pintle mount and easy access frame bolts if you know or are a welder. Hmm. Good idea for a money maker for me!!! Who wants a ez mount 2" receiver that hangs out right below the pintle??
C
I'd be intereted in seeing those pics too. TIA!Yes, the Blazer's do use a different hitch than the pickups do. The width between the frame rails is the problem. The Blazer's frame rails are closer together.
You do need to remove the support bar for the hitch. I plan on cutting my bar down and welding it in between the braces of the hitch, then I can bolt everything back up. I also had to leave one of the bolts out of the passenger side tie down loops. I've got the bolt in there now and it won't come out, but I can't get the nut on the bolt. I plan on welding it in place to sometime.
It is sort of hard to get the bolts in and tightened down, but not impossible.
You do NOT have to drop the tank to do it. I think that would be an even bigger pain.
You will also need to hammer the safety loops up to clear the hitch. They're still usable, just not hanging down like before.
I ordered the Valley brand from O'Reilly's for my Blazer.
I can post pics of my setup sometime if someone likes.
I'll try to post those up tonight or tomorrow.I'd be intereted in seeing those pics too. TIA!
Sorry, still haven't had a chance to get pics, but I can answer your question. I guess I missed it the first read through.Rider...Pics would be much appreciated. When you say you have to remove the hitch support bar, do you mean the Pintle hitch support bar? I have no pintle hitch but the bar that bolts between the lift shackles and the frame is still there. Is this the one that has to come off?
SCoutdoors
