CUCV m1008 volt meter problems
dmilkman589
troy, ny
DogHead, correct me if im wrong but when following diagram for the voltmeter It starts on E-6, flowing that to the relay, then following the lead the relay gets power from references you to pg E-9, here the wire is going right into the glow plug module.
Warthog
245
OKC, OK
Diagram E-6 (F-6) is for the M1010 Ambulance.
The diagrams you listed do not match up. Can you at least reference the wire numbers you are talking about?
Warthog
245
OKC, OK
Okay we are using the same diagrams. What is the wire number you are tracing?
