CUCV nv4500 swap
0311
nunica MI
Hello, this is literally my first post in years. I have a 84 cucv m1008. I took the turbo 400 out and 208 out, I got a brand new Nv 4500 1996 model with a nice used 205 T case, the T case is the round 6 bolt pattern and I got the round adapter ring spacer for mounting it to the trans. The truck is currently stripped only the cab and motor are in it as I completely sand blasted and coated the entire chassis and fixed and repaired all corrosion on the cab. Now I’m at the point of doing the swap but I’m at a standstill as to what i actually need for the parts I have to complete this. My question is what slave cylinder, clutch master cylinder and resvoir and what fluid line do I use? Do I use internal or external along with what bell housing and starter do I need? The truck has about 3 inch’s of lift on it atm. Secondly what type of clutch kit do I use and flywheel? It should be noted I already have a complete hydraulic clutch pedal assembly that came out of a Hydraulic 4-speed truck. And lastly can I use the original tranny crossmember? Is their a kit to make that work by chance? Thank you so much to whoever can point me in the right direction with this, also I apologize in advance if this post isn’t in the right spot or if I’m doing something wrong on this site as it’s my first time on here in years and I’ll get the site etiquette down as time goes on. Also feel free to let me know if there’s anything else I’m missing here thank you so much.
