CUCV shifting HARD hanging on to gears far too long.
DrFoster
Cheyenne, WY & Condado, PR
One other problem I need ot work out on the 84 6.2L CUCV I'm working with is a hard shift issue
Again, only 61K on it. When shifting at low throttle, it hangs on to the gears way too long, then finally smashes itself into the next gear.
Under full throttle, it shifts smoothly and on time.
Any advice here is also greatly appreciated.
Thanks!
Robert
CCATLETT1984
Saint Clair Shores, MI
check the vacuum lines, sounds like you have a vac leak.
if lines are good check how much vac you have at the trans at idle.
if vac is low, it could be the regulator on the side of the pump, or the vac pump itself.
Hasdrubal
Vancouver BC
My M1009 had the same symptoms, the vacuum regulator has failed, its the black plastic unit on the side of the IP with all the rubber vacuum lines coming out of it. Quick ad hoc fix that I did was to switch the lines around on the unit so that the line coming out of the vacuum pump is connected directly to the line going to the tranny. Shifts early and smooth, only drawback being you have to manually shift into 2nd gear when going up hills.....Cheers
