Cummins 8.3L Factory Coolant Filter
74M35A2
340
Livonia, MI
I recently discovered the 8.3L was equipped with a factory coolant filter integrated into the thermostat housing on some applications. I have ordered one from eBay, and will try it. From a quick visual, it looks like it will fit, we'll see. Notice the horizontal filter behind and above the alternator.
The Cummins factory part number for this housing is: 3926508. It is a dual thermostat housing.
74M35A2
340
Livonia, MI
This may not work for us. There is no down leg to support the flow to the trans cooler. Once it arrives, I will better assess, but tables have turned on it. Also, it may heavily interfer with the A/C bracket I crafted.
3,164
IIRC, there is a plug to install in the head or block that forces coolant flow through the trans cooler in closed stat operation.
74M35A2
340
Livonia, MI
Understood, thanks. It Is probably going back on eBay after I see it to not have the correct porting for our trans coolers.
