rustystud
- 3,392
- 113
- Woodinville, Washington
Picture one shows the bolts and straps going on. I used stainless steel bolts with "Marine Grade" anti-seize on them. Picture two shows the scribe marks on the "Impeller Housing" and "Bearing housing". Picture three shows the drain tube installed. You can leave the outside bolt loose as the "Draft" tube bolts here. Also install the drain tube "hose" now. Just push it up on the drain tube, then after the turbo is up you can pull it down into the block tube.What temp is the marine grade anti-seize rated to?
Yes, there are a number of places that carry the rebuild kit for the "C" turbo. I paid $100.00 for mine, which (until I get a good turbine) be setting on my shelf collecting dust.Midwest Turbo has the 3LD / 3LJ rebuild kits for the Schwitzer whistler "C" at a reasonable price. Claim it is US made.
Here is the information for a rebuild kit. http://www.invasionautoproducts.com/otvatu3112.html
Part #318385 .
Also for those who want a new Chinese "Whistler" Turbo here is the link. http://www.invasionautoproducts.com/19mutr3ltu11.html
