Dash brake light
1,827
If you have a brake light on the dash, you've probably got the dual circuit brake system. If so air in one circuit could be enough to trip the pressure differential switch assuming it has one. I've also seen these lights retrofitted as a parking brake light. Look underneath and see if it has 2 airpacks, one on each side.
sermis
17
Temple, TX
I just got the Duce. Had been sitting for some time. Did not have any breaks at first, bleed the system and had little and then it was like the air started working and now it stops fine. good enough to slide the wheels..
Only remember seeing one air pack, will look again.
