dash light upgrade?
mattwspeed
Clrkesville GA
Looking to get better lighting for the dash gauges on a truck. Looking at possibly LED's behind the dash or much brighter bulbs. Has anyone had any success with making the gauges brighter at night? We can come up with something im sure but if others have any "been there, done that" ideas it would be great. Thanks guys
Artisan
227
CDA Idaho
Guys have drilled holes in the lens's in just the right spot
to let a lil more white light pass thru.
jonesal
Mission Specialist
69
Brookings, SD
I switched to clear lenses and it's much brighter. I had to take the original ones, use a heat gun to remove the red lenses from the brass fronts. I then used clear lenses from the indicator lights above the steering wheel to insert in the front brasses. MUCH brighter and white. I need to put in new rubber gaskets and I can finally see what's going on.
Al Jones
cranetruck
75
Meadows of Dan, Virginia
Here are my preferred options.
Believe it or not but the lens with holes was actually original to my '69 xm757. I had done the same to my old cranetruck and was surprised to find the same solution on the 757. Could be a GI-fix at some later than 1969 date, of course...
The reason for the shorter bulb is to place the filament lower in the fixture for better "aim" of the light.
cranetruck
75
Since driving the cranetruck at night with poor dash lighting was not a good experience, I kind of went overboard with options on the 757, in addition to the external panel lights, (here seen turned on), there is also an overhead dome light.
2008 0517 xm757 mini dash, instrument panel lights, illumination, backup light switch, turn sign.jpg
73m819
314
gainesville, ga.
I also use a armored cab light, not only helps me on the gauge visual issue, It also allows me to look around the cab if needed with the blue (looking for red) light, then the white light is great for reading directions on the side of the road at O dark 30 when I think that I just passed my turn.
