Keith_J
- 1,328
- 113
- Schertz TX
Back in 2012, my 1031 developed serious death wobble, the steering stabilizer was leaking oil and corroded so I replaced that along with the upper kingpin bushings and springs. This cured it.
Doing my annual service last week, I greased everything and suddenly DW returned. And the steering stabilizer is leaking oil.
I took the left king pin cap off, comparing bushing and spring with the original ones that had DW originally, no wear on the bushing and the new spring is still 1/4" longer. No play on the lower bearing.
the truck had 9009 miles on it in 2012, DW started about 12000 miles on the odometer. It now has 16800 miles on the odometer.
I will ill replace the stabilizer and look for heavier grease. All I have used is GAA, the original grease was red lithium.
