deuce brake adjustment
kx250m1
sturtevant/WI
I want to adjust the brakes on my deuce, as they work very well, but pedal must be pushed about half way before they start to grab, if you pump them once, they are very firm from the moment you touch them, so I assume it is the adjustment, my problem is that I am having a hard time finding how to do the adjustment. Pictures with directions, or a link, would be much appreciated.
thanks,
kyle
1,827
Refer to TM 9-2320-361-20 (Its in the resource section under technical manuals) and check it out. Plenty of pics and advice on minor and major adjustments.
doghead
4 Star General /Moderator
1,193
NY
If it(TM) takes a long time to load or wont load, right click on the manual and save it to your computer. It will save fast, and you will then have it anytime you need it.
