Deuce door hinges
FrankUSMC
33
Newport, NC
Man, I am going to go "right" now out to the barn, I have two doors that might have the hinge on them. Sorry, I did not do that on your first post, but I saw were a couple of guys responded and thought you were hooked up.
One of the few, Frank
Rocco
Lynchburg VA
Thanks A lot.
Most of the time they are stuck,
I just heat them up with the torch and give them a tap and out they come.
Thanks again.
FrankUSMC
33
Newport, NC
No luck. One door had it's hinge torched off and the other was just the hinge part that is bolted to the door. You needed both hinge parts right? the one that is on the door and the one that is bolted to the cab?
Now, do not do yourself in....yet. I still have to more doors down at our farm to look at. I will be there tomorrow after church.
FrankUSMC
33
Newport, NC
Rocco
I have a door that has both hinges still on it. I put some oil on the screws tonight to let it soak.
Ok, I take out the 4 screws, that are holding the hinge to the door. Does the hinge come out at that point? Or do I need to hit it a few times with a brass hammer?
Rocco
Lynchburg VA
If the door is off the truck
you onley have to remove 4 screws then
it will come off ,you might have to hit it.
Thanks a lot.
