poppop
- 39
- 48
- Brooklet, Ga
My Duece starting draining the batterys several weeks ago. When I disconect a battery cable and touch it back to the post I get a little spark. I started disconnectiog things until the spark went away. It seems the alternater is the problem. I replaced it with a take out I got from papabear with the same results. Both charge great but produce that spark at the batterys when hooked up. I have one more alt to try and see if itis good. I have been disconnecting the batterys when I am not using the truck but is agrivating to have to do that all the time. My question is this, can I run the big power lead that goes to the alternater into the cab and put a disconnect switch there to break the power to the alternater?? If i do that and someone starts the truck without suppling power to the alternater will that burn up the alternater?? Does anyone know what part in the alternater will cause this problem?? I am assuming it is the voltage regulater as I have had that problem with regular trucks. Does anyone have any insight on this??
