gimpyrobb
dumpsterlandingfromorbit!
- 27,787
- 779
- 113
- Cincy Ohio
The FDC should have nothing to do with your issue.
Try what I recommended, ideally you want to manually disassemble the parts and clean them but there are bits you cant reach and risks associated. Even after I cleaned mine I still had some issues until running a highly solvent fuel mixture for a short period of time until the problem went away.Did you ever figure out what was going on with your truck? I have the exact same symptoms (see "Oregon m35a2" post from me a couple of weeks ago. I found that my pump was missing the droop screw and figured that was the issue. I replaced it, and while the low end response is much better, I can't get my truck to settle down and idle.
Not to hijack, but auto trans fluid will clean out the fuel system?I can't speak for all the trucks, but some that I have had, had been sitting for a while and just needed time running. I dumped some ATF in the fuel to help clean the fuel system. After a couple weeks of driving, they calmed down and had smooth idle characteristics.
Not sure if that will apply or not, just what I have run into.
Thanks Gimpy! I will remember this.ATF is highly detergent, yes.
