deuce Inner wheel seal.
Rocco
Lynchburg VA
Whats the best tool to remove the inner axle wheel seal?
gear oil was coming out of it so im trying to get it out.
All I have is a slide hammer.
You think i should heat it up?
JDToumanian
14
Phelan, CA
Slide hammer usually works. Bjorn's method is to use a 6' long 1" dia. metal rod to pop the seal out from the opposite side, with the rod running all the way through the axle.
FreightTrain
Banned
2,730
13
Gadsden,Al
I tried a slide hammer and couldn't get mine to budge.I have to use a 3/4" Black Iron Pipe run though the tube and a BFH to drive the seal and retainer out.Took about 2 solid hits with the hammer to pop them out..
devilman96
17
Boca Raton, FL
If you still have a new seal in your hand can you please post the number so I can cross it for the parts section... I forgot to do that when I had mine loose...
ken
26
Houston Texas
Unless your doing both sides. The slide hammer keeps you from having to take the other side apart.
Rocco
Lynchburg VA
Nothing on the seal.
But heres all that it says on the bag it came in.
5330000751764
5330-00-075-1764
CAGE:1P117
PN:19207-8738032
SEAL ASSEMBLY 1EACH
SP0540-04-M-C653
M31-6/04
Timberwolf
Westminster Md
i put a piece of 1/2" x 1" Flat bar across the end of the axle sideways,
and used a Puller with the arms with the hooks out. a quick buzz with the impact, and its out.
i'd tried a bunch of other methods before i figured this out.
side note..........
has anyone tried the upgrade seals ? i got 4 this time, and then upgraded my rear axle to the 2" 47 Spline from OEM before i installed them,
so now i cant use the back two cause the ID is too small for the axle to go thru.
