deuce ip problems
general dietrich
bought my first deuce. Was told it had a bad fuel pump. Turns out fuel pump works but ip bad. Took head off ip and had broken shaft. Does any one know the steps to aline the timing up. So i could remove pump and replace it.
wsucougarx
Check out the "resources" tab on top of the page and go into the Technical Manuals. All of the TM's are in there. Just find the TM you want, print off the page and get wrenching;-)
dkeven
I appreciate the constant reminders to look in the resources for the correct TM, perhaps the correct TM number could be posted at the same time to make it easier to find. Don
wsucougarx
It's amazing how many people don't know those TM's are there. And why would they unless they stumbled upon them themselves or have been given these constant reminders. I probably should have made it easier by giving reference to the correct TM designation. However I have found, by reading through all the TM titles, I have found several TM's I didn't know existed.
dkeven
appreciate the attempt at educating the masses about the tm in the resources have seen this posted several times, having gone to the tm's myself several times i find them not in any logical order, seemingly duplications exist and the heading do not tell all the contents. After downloading several I have created my own reference library. Still I find myself having to open more than one to get to what I wanted. Just think all the effort to send someone to the resource could at least reference the tm number or even have a link. Like a signature I come upon occasionally if the search function was used in its entirety this would be an archive not a forum.
doghead
4 Star General /Moderator
A few minutes(or even hours) searching for "hydraulic head" would have helped you find this recent thread covering your question.
http://www.steelsoldiers.com/deuce/14688-multifuel-fuel-pump-hydraulic-head-removel.html
Also, as you type in your title, you will get a list of "related threads". This is where a good thread title helps later.
When you see the instructions posted by Floridianson, right click on them and open them in a new window, to best view them.
cranetruck
The "search" feature on the site is poor IMHO. If you want results, go to Google and type in keywords (within quotation marks, which is ignored on this site) and add "steelsoldiers" as one keyword. You'll get lots of hits with links to this site for "injection pump" "timing" etc.
The TM section is not well organized and it still takes a lot of research to find answers from TMs, this forum is great as long as questions are specific.
dkeven
now that works great thanks for the heads up!
