Deuce Master Cylinder
dan2002dd
23
ellaville, ga
I have been unable to find anyone talking about bleeding a new master cylinder for a deuce. Is there a bleeding procedure before installing it or is it just gravity bleed by opening the bleeder on the air pack? Next question is the new MC came with a rubber cap that is not vented, can this be used or must the MC have a vented cap?
dan2002dd
23
ellaville, ga
So I just got a chance (and all the parts for the one man bleeder) to finish the bleeding process and found out the rubber cap and the old master cylinder cap are different sizes. I'll have to try to measure to see what I need but has anyone else run into this situation? Is there another cap that fits this smaller size that anyone knows of?
dan2002dd
23
ellaville, ga
I guess that's an option but I'd really like to use a metal cap even if I had to drill it out. I may go ahead drill this one and be done.
dan2002dd
23
ellaville, ga
I drilled a vent hole and bleed everthing last night with my wife's help. Of course I had to run the master cylinder dry one time before starting over, she was very excited about that. I'll check it later to verify it stayed pumped up, now I have to deal with a new belt for the compressor. I think the pulley is froze up so I may be back for more advice on that.
