Deuce U-joint
jluv1185
baton rouge/la
I called saturn surplus today, and the man while very nice couldn't tell me which u-joint was the one I needed. I wasn't cofused before I called, but when I hung up he had me second guessing. Can someone tell me what part # I need to order for the drivshaft to the front axle? I think its part# 5702987. Here is the link to the page. Saturn Surplus
Thanks,
Justin
spicergear
26
Millerstown, PA
that should be the correct one and seeing how the duece doesn't have a pillow block and the one third listed M35 U joint has the two bolt flange on it, 1500 series which are ONLY on the driveshaft going from the t-case to the front tandem...you should be okay ordering that 570.... part. btw, the jackshaft between the tandems and the front axle should be the same 1410's.
