Diesel Fuel Purge
beckel
Austin, Texas
Guys - After hours of searching the web I cant seem to find a solid description of how to do a diesel purge on our HMMWV. I reviewed the K5 board 6.2L purge but it is a bit different than our setup it appears. I put together a simple block diagram that I wanted to share with you guys to see if you thought this would work. I have a sticky injector that I want to fix before replacing them so hoping this might work.
beckel
Austin, Texas
Sorry guys. A diesel purge is when you run 100% injector cleaner through the injectors rather than just adding it to the fuel. I have a sticking injector that might improve if I can get it clean. The purge requires that you bypass the pump and draw the cleaner at full strength.
dilvoy
25
San Francisco, Ca.
Try plumbing your "mechanic in a can" via the fuel lift pump. You can connect a hose to the fuel pump suction connection and put the other end of the hose into the bucket with the Magic juice. You will need to connect a little hose from the fuel return line to go into your little can too. That way you can run on the fix it stuff for as long as you want too, with whatever diesel that was in your injector lines and filter diluting it. Does the can that the injector rebuild fluid comes in say that it can be run through an engine at 100% strength without damaging it?
Retiredwarhorses
4,472
Brentwood, Calif
I have a better idea....find and fix the injector. Don't bother with some miracle that may come out of a can.
its quite simple to find a sticky injector....just start the truck and start cracking lines till the noise goes away.
you can also pull all of them and send them out to a shop,and have them pop tested. "Preferred method".
this way you will really know how all of them are...my dealer charges nothing for pop testing.
beckel
Austin, Texas
Agreed...I found a new (surplus) set of injectors for $180 so I am going to just replace all 8.
