diode for wiring to gen 2 light. Where is it?
ida34
30
Dexter, MI
I am trying to track down the cause of no gen 2 light on one of my cucv's. The wiring diagram shows a diode and this is the only thing I have yet to check. The relay checks out and all the it is triggering properly. I really think the diode is the problem but where is the damn thing?
Chuck
acetomatoco
Could be one of those plug in units on the left fender well... I have never replaced one..though...The 20 and 34 give good schematics.
ida34
30
Dexter, MI
They will charge but not till you get the revs up. The alt will not energize until the engine is reved up without the light. I drive alot of stop and go so I need them to charge at or near idle too.
Michael
24
Fulton, MS
I have had a lot of trouble with corrosion in the light sockets in the dash. I ended up pulling the dash out and cleaning all of the contact points.
ida34
30
Dexter, MI
The dash is good. I want to get it working right with a working light so I will chase down the diode. When I locate it I will post. The dash socket has no problems. I have already checked it. Thanks for the responses.
481
10
Charlotte, MI
Me too. I found out that my second alternator was not charging the battery because of the cluster corrosion. Charging better than ever after pulling the cluster and cleaning the printed circuit connections and the sockets.
dsouthwick54
WILLITS CA
Chuck
The Diode for Gen 2 is behind the voltmeter
