do any of the 5 ton have air shift
D
Deleted member 11142
Guest
I'm not 100% sure...but I'm pretty sure they don't. There has been talk of people putting a 939 tcase in an 809... But I'm not sure if anyone has actually done it.
73m819
329
gainesville, ga.
no air shift in the 809s and the 54 series
opcom ?? put a 900 5t xcase in a 818
Squirt-Truck
Master Chief
164
Marietta, Georgia
Guys,
The 800's and the M39 series have air shift sprag selection. No air shift for front axle drive UNLESS the air system modification has be done that allows neutral or front drive.
The same only different from the 2-1/2 air shift.
Squirt-Truck
Master Chief
164
Marietta, Georgia
The transmission is standard shifting, but there are air valves on the first/reverse shift rail that direct air to the cylinder on the transfer that selects forward or reverse sprag. The air system modification is to cut-off the air to the selector valves which puts the front drive in neutral. Without this modification the transfer is always in forward or reverse, depending on the shift rail position.
