Door Latch Spring Replacement
Menaces Nemesis
"Little Black Truck" Conservator
259
Denver, Colorado
Broken Door Latch Spring Replacement
Forgot to mention in the vid that you'll need to remove the OUTER door handle as well as the inner handle to remove the latch assembly... Made this on the fly while fixing a broken door latch spring. The vid is a bit shaky and choppy, but I'm happy with the coil spring conversion method I came up with. Door latch springs can be converted to coils for less than $5 ea.
https://www.youtube.com/watch?v=Utfm_4vh2RU
Compression Spring; https://www.homedepot.com/p/Crown-B...x-0-032-in-Compression-Spring-79148/203577664
Cotter Pin; https://www.homedepot.com/p/1-8-in-x-2-in-Stainless-Cotter-Pins-2-Piece-815348/204276203
#10-24 x 1/2" Flat Head Screw; https://www.homedepot.com/p/Everbil...at-Head-Machine-Screws-8-Pack-28511/202706135
#10-24 Nylock Nut; https://www.homedepot.com/p/Everbil...el-Nylon-Lock-Nut-4-per-Pack-800121/204274165
#10 Flat Washer (must be at least .040" thick); https://www.homedepot.com/p/Everbilt-10-Stainless-Steel-Flat-Washer-12-Pack-800331/204276461
