Door panels and windows
Matt S
35
Los Angeles, CA
I needed to replace my door lock on the driverside. As it always is, the last few screws ruined a quick job. The door pad screws were rusted so bad that I broke 3 drill bits trying to get them out. In the end, I pryed off the arm rest and I now need a new door panel.
There are quite a few choices out there but which ones are worth it? I see LMC Truck but the reviews are they are really thin. Coverlay makes some that I found on rock auto but they don't look quite the same.
I also need to figure out why my drivers window keeps coming off the track. I tried to pull the back track in but I might have to find another adjustment as it won't come in further.
cucvrus
9,619
Jonestown Pennsylvania
I know a guy in Pennsylvania that has a few OEM used CUCV door panels. A few. Are you interested? Let me know. I even have Blue ones that are stock blue thru and thru.
Matt S
35
Los Angeles, CA
Do you have the felt channels on the front and back of the door glass? The front channel has an adjustment as well.
I'll look into that. It moves just enough to pop out but I'll look. The felt is still in there but it's original.
Matt S
35
Los Angeles, CA
Thanks! I have the door panels but they are all chaulky and I'm not sure I could save them. If I had to reuse them, I'd need a new arm rest and the felt piece is brittle.
Since I want them to match, I figured a trying something new but not sure who to go with.
cucvrus
9,619
Hey and the next time that happens where the arm rest screws are rusty and you can't drill them out. Gently pry out on the door panel and get a ratcheting wrench up under there and remove the 2 1/4" bolts that hold the metal arm rest bracket in place. It is that easy. Then you use a vise grips on the pointy side of the screws and get them out. No need to go all H.A.M. on that poor door panel. And another trick that is worth trying to rejuvenate the door panels is. After they are removed and cleaned. Hang them up on a string and soak them down with Armor All. Let then set a day or 2 and hit them again with Armor all. After the set and dry clean them up with a soft rag and you may be surprised. They won't look perfect but they will be acceptable and match the age of the truck.
Check it out. I wanted an original truck. I changed very little in interior parts. CUCV head gasket / head/ or change engine survey | Page 7 | SteelSoldiers
nyoffroad
624
Rochester NY
DOH! After all these years and all those rusty screws NOW you tell me that? Just goes to show sometimes it pays to look 'outside' the box. Thanks for the tip!
Matt S
35
Los Angeles, CA
Well....I can see what you're saying now that the panel is off but in the moment that never crossed my mind. I'll have to ask next time before I start with a pry bar.
When you say clean - What do you use? Soap and water or degreaser or ?
Barrman
1,572
Giddings, Texas
Contractor trash bags from Walmart are pretty good at keeping the cold wind from coming in through the door handle in the winter has been my experience. Held on with duct tape of course.
