Isawfrizzy
- 0
- 6
- St. Paul, mn
When you go to drain the air tanks after driving how much volume should you get out of the wet tank? Yesterday I let the truck idle and build up pressure in the primary and secondary tanks (120 psi). I shut it down and got distracted and forgot to drain the tanks. Went back a couple hours later and the wet tank had almost no pressure when I opened the drain. The primary and secondary had much more pressure and volume when I opened those.
Should the pressure and volume of the wet tank be comparable to the primary and secondary tank when you go to drain them? Should I start chasing leaks?
