Drivers door window regulator replacement.
85CUCVtom
25
Lakewood, Ohio
So my window regulator is all jammed up and won't roll up or down. I have a new regulator and was wondering if anybody has had to replace one? I'm just looking for any advice or tips to make it a little easier. Thanks
RedBlok
Springfield Va
Did you ever figure out how to replace it? My M923a2 has the same problem. I just got my truck this weekend
Thanks
Adrian A
Fresno Ca.
Just open the access panel and lubricate every thing that moves. You likely wont need to replace anything as long as the runs are in good shape. Make sure your rubbers are not destroyed.
RedBlok
Springfield Va
Thanks Adrian.
I found the TM today and started reviewing how to fix it. I appreciate the response
Rob
