- 34,010
- 1,827
- 113
- GA Mountains
Thta M45A2 was once I fire truck I believe. 530B or 530C as evidenced by the outboard air tanks. Does it still have the heater on the passenger side floor/forewall?
The 5 Ton ISO bed has taller sides and there are two panels per side, not one. They're largely a USMC thing and they handle 2 6'x6' ISO boxes or one each of a 6'x10' or 6'x12' ISO box. They have an unusual but still ISO type turn lock that you lift, turn 60 degrees and then when the container is dropped on the ISO lock, you then turn it back 90° and that locks the corner down. They recess in the bed when not in use. The USMC ISO bed has provisions for storing the dropside beds and tailgate under the bed between the bed frame rails. There's a panel on the back that comes out to allow one to do so.rice said:What are you referring to as an ISO bed?
