Dual stacks on M939A2.
4x4 Nut
New Knoxville, OH
Hello, we recently built a headache rack & dual 8" stacks for a 5 ton w/ 8.3 Cummins. Changed the entire system including a new 5" down-pipe off the turbo which follows the original path under the cab to a Y-pipe mounted between the stacks. The headache rack gave us something solid to mount the stacks to plus adds some welcomed protection for the occupants. The air intake is plumbed into the headache rack tubing via 90 degree elbows at the top of each vertical 4" tube. From there it travels down to the bottom where a 5" pipe connects it to the factory air box. Worked out well I feel. I've seen some other stacks on various trucks posted on here & just thought I'd share our version too. Have a good one.
https://scontent.xx.fbcdn.net/v/t1.0-9/17798987_10154232532112522_9185294940152991183_n.jpg?oh=3fa1cd1558bb0ac6e2276fdecb0c09b6&oe=59786211
https://scontent.xx.fbcdn.net/v/t1....=1f01d7705de1061430e495d5ccf24794&oe=59917252
https://scontent.xx.fbcdn.net/v/t1....=df8301401eb6dcc07a042db2e1cd801f&oe=59BE0DAB
Sorry, but I can't seem to find the proper way to link the image from Facebook (unless it's not possible)...
Tinstar
1,712
Edmond, Oklahoma
Hope your gonna park it inside.
Those are going to catch some serious rain water.
Looks good
I personally think it would look better if you painted them to follow the camouflage outlines.
4x4 Nut
New Knoxville, OH
Thanks guys- appreciate the compliments. I'll post some more pics sometime soon.
Tinstar, it's outside, but found some perfect little buckets to cover the stacks with. It also has some 1/16" drain holes in the very bottom to prevent water from collecting. Color matched would've been a nice look too, but I like the flat black a bit more. The truck's also going to get repainted at some point anyways.
Here is a shot of the stack pipe assembly before the headache rack was built. That is a 5 gallon bucket there...
https://scontent.xx.fbcdn.net/v/t1....=dac52fed4c2d9ed1464cc3f82b9c9509&oe=598638B7
Closer shot of the headache rack. The (2) elbows below the top bar are the 4" inlets for the air intake. On the bottom side of the lower cross tube you can see 2 bolts. This is where the 5" pipe connects to go forward to the air filter housing- just like the factory snorkel did.
https://scontent.xx.fbcdn.net/v/t1....=c3cfc789766aa339efd079faf450026d&oe=59C2F11B
1,168
We ask you to attach photos, not use links.
snowtrac nome
137
western alaska
im not a big fan of the straight stacks when it rains they fill with water and blow black garbage all over your rig. my Thiokol 2100 came that way after a stormy 3 week barge ride it must have pumped 5 gallons of water out of the stack on first fire up. the whole rig was covered in black slurry
71DeuceAK
346
Fairbanks, Alaska
SnowTrac Nome, my way around that would be some buckets or custom made covers, but I can also see that putting them on and taking them off could get old quickly.
1,168
Try posting a thread in the website help forum.
74M35A2
313
Livonia, MI
Pretty cool. How can anybody in this hobby not like big crazy pipes? If it is stainless tube, I would not cover them for rain. You could sell quite a few of them here if you really wanted to.
Thread should move to 5T mod dept.
