- 6,888
- 2,274
- 113
- Montevideo/Uruguay
Based on cranetruck's experience (thanks again, Bjorn!) I finally completed and tested my conversion to let my LDS427 run on SVO (pure sunflower salad oil).
I build the “combi” tank cutting up and welding together parts of a second tank and installing a heating coil inside the main section. Two external inline pumps do their job sharing the same water separator and fuel supply line to the engine filters. Two return lines, each fitted with a solenoid valve, keep the fuels separated.
The cold engine starts on diesel, is than manually switched (see toggle switch on dashboard) to SVO after approx. 15 minutes of warming up and back to diesel before stopping for a longer time.
With SVO the warm engine starts immediately, after 24 hours at 20ºC (68ºF) it was not so happy but came to life on the first intent after cranking for about 6-8 seconds. I didn’t use the extreme cold starting device.
At highway speed switching back and forth between diesel and SVO there wasn’t any noticeable difference in performance! Only the exhaust smells very different…!
Time will tell if there are any mechanical drawbacks of using this CO2-neutral fuel alternative in our Multifuels, hopefully not!
Attached a few pics of the components.
Gerhard
Gerhard
