johnjr
- 2
- 8
- hammonton n.j.
Just installed an Airtex 8131 elec. fuel pump on my 85 1009. Used a lighted toggle switch to energize, no regulator,added a 2 micron napa spin-on filter, after the pump, before the stock filter, bypassing the mech. pump. Truck runs good , my only concern is the pump never shuts off until i switch it off. Without truck running and pump switched on, I would think pump should build up pressure and shut off. There are no leaks, is this normal? Is fuel just returning to tank? FYI I did this mod in prep for running WMO. Thanks!
