StoneyHill
- 0
- 6
- Florence SC
I need a little help from someone who has a better understanding of the wiring of the M1009 than me.
I have looked at the Wiring Diagram on page 874 of 940 in TM 9-2320-289-20 in figure F-20. I tested the voltage at the plug before the suppressor assy. I have no voltage between the gray/white on with the column switch on low and no voltage between the purple/white with the column switch on high. I tested a working M1009 and there should be roughly 12volts there.
I understand that that usually points to the switch in the steering column. My question is this however: I have 12v across the slot for the 25amp fuse in the fuse block in the working truck. I have no voltage across the slot for the 25 amp fuse in the truck that is not functioning. Before I try to access the switch in the steering column, I wanted to make sure there is not a problem with current to the fuse block.
If it is the fuseblock, how do I test/troubleshoot it?
Any tips/help is appreciated.
Thanks,
SCott
Thanks,
SCott
