hedelta
- 2
- 18
- Glen Arm, MD
I will be wiring up a 24v to 12v converter in my deuce. My question is can I ground my accessories to the frame or do I have to run it back to the converter. Thank you.
Although I agree with DrGreg, I would run my negative all the way back to the converter. This will eliminate any "to frame" grounding connection problems. Just my 2 cents.As long as the converter ground is to "frame" the systems should not see any different potential. So yes you can use "frame".
The battery.Hey sean what did you use as your 24 volts source
Is it out of my shop yet? j/k
