Emergency flashers question.
bikeman
501
Ft. Bragg, NC
Should be an additional switch spot on your turn signal lever... all the way up? I don't have one, so I'm basing it off of my HMMWV use...
Keep in mind that the flashers will probably may override your brake lights.
Flyingvan911
158
Kansas City, MO
There's a little button on the turn signal switch. Press it down and turn the lever toward the right turn position but farther. Like some older civi vehicles, the hazard lights stop flashing if you press the brake pedal.
