- 4,640
- 32
- 38
- Cambridge, Ohio
Hey all,
First off I did search. Maybe I wasn't using the correct search parameters, but I did look.
I have a question about the multi in my deuce. I never really cared much about it until I was looking at a post by another member trying to re-time his hydraulic head. cranetruck posted a few images from the TM about the timing marks and procedure and I noticed that the timing mark used for the LDT and the LD are different, and that's when I figured I better find out just what I have.
I know the most of the deuces have the LDT in them. I also know that the LD's were originally non turbo engines, but that some of them may have been converted over.
The engine tag in my truck is badly worn and you cannot make out anything on the tag except for the fact that it is a Herculese engine...you can barely even see that it is a multifuel on the tag. Are there any markings on the engine that would let me know what engine this is for sure, before I run into a situation when it will matter and I don't know what I've got?
It is a TD block and was rebuild in 1994. From what I've read the TD was a later change made to the engines so i'm thinking I don't have an LD that was converted to turbo. But how can I tell what it is for sure? Is there another casting in the block I can look for or something? I can almost rule out the LDS as well, since it doesn't have enough power to be the LDS.
By process of elimination I could assume that it is the LDT, but we all know what happens when you "assume"...I want to be positive of what it is.
Thanks in advance
Thanks in advance
