acme66
- 9
- 0
- Plains, Montana
So I have been designing and building a 24v pre-oiler for our M925A1 (NHC250) and have it all done but the squealing. It is compact, robust, clever, adaptable to any truck and quite cheap if I do say so myself. I have come to a sudden crossroads however and wish to consult the hive mind.
My plan had me injecting the pressurized oil at the front and rear most block oil journal plugs on the driver side. I was using two because I felt that small size was going to limit the volume of what I could force in there. It just occurred to me however I could inject full volume oil through the oil test port on the oil cooler. Any educated opinions as to which location/method you feel would get the most oil to the important silver turny bits?
My pump is capable of 25-30psi but in all honesty I would be thrilled with just 5psi at the crank, rod and cam bearings.
Thoughts?
Ken
Thoughts?
Ken
