DaneGer21
- 1,163
- 93
- Creston, Ohio
(6) rockers and (2) gaskets came to $314.40Maybe we can get a group buy from BM to lower the price a bit?
Part# 11641735What PN do you have for the rocker arms?
If your valves are worn, just replace them. Since your removing the heads anyway, just have the machine shop check the valve guides. They might be fine and the seals are just bad. Since the seals are not much on the deuce, I would have the machine shop "machine" the top of the guides to except a modern oil seal. The modern seals will last decades under daily use.Since the exhaust is clean would you recommend only replacing the intake guides? Intake valve stems are close to the limit so I was planning on reusing them. I don't have a .0001 mic so not certain how close. Bad idea?
I didnt see any reference in my manual on valve guide seals. that doesnt mean they couldn't be added though, if he cant get new valve guide inserts. Am I missing it somewhere?If your valves are worn, just replace them. Since your removing the heads anyway, just have the machine shop check the valve guides. They might be fine and the seals are just bad. Since the seals are not much on the deuce, I would have the machine shop "machine" the top of the guides to except a modern oil seal. The modern seals will last decades under daily use.
If the guides are a bit worn they can just "knurl" them. They will last a long time after that procedure.
The ones I have seen where just "O" rings riding on the valve stem.I didnt see any reference in my manual on valve guide seals. that doesnt mean they couldn't be added though, if he cant get new valve guide inserts. Am I missing it somewhere?
The machine shop should be able to machine down the guide to except the valve seal. It should clear the springs just fine. There pretty small.Can they be added with those valve rotor things in there?
If I end up having to replace guides and valves, I won't mess with adding seals. Otherwise, it will depend on the cost for P&L.
usually valve guides are a brass alloy that is considered to be self lubricating. At least that is the way I understood it.Any chance that adding seals where none were intended to be could cause the stems to run "dry" and accelerate wear? Something to consider.
Agreed, but some years back we added valve stem seals to an old tractor engine during a rebuild at the owners request. Less than 50 hours late the guides were shot and the tractor was smoking. Went back in and did the guides again but without stem seals this time. That tractor is still running smoke free some 20+ years later. That experience always pops up in the back of my aging mind when dealing with older engines/technology.usually valve guides are a brass alloy that is considered to be self lubricating. At least that is the way I understood it.
No argument there. One could also look at it from the prospective that if it doesn’t smoke without the extra seal then why add it. But that is interesting though I would never have thought that adding valve seals would ever cause excessive wear. That is one of those things that you would never know until you tried.Agreed, but some years back we added valve stem seals to an old tractor engine during a rebuild at the owners request. Less than 50 hours late the guides were shot and the tractor was smoking. Went back in and did the guides again but without stem seals this time. That tractor is still running smoke free some 20+ years later. That experience always pops up in the back of my aging mind when dealing with older engines/technology.
Not right or wrong. Just something from past experience.
We never heard of it - and probably never will...Has anyone here successfully added seals to a multi fuel?
I've got considerable oil leaking through the valve guides. So I may have to choose replacing all guides and valves while the heads are off being worked or I was thinking valve guide seals might be a way to go. But sounds like not a good idea.We never heard of it - and probably never will...
Really, for me that would be the absolute last thing to do, from a long list of possible improvements for these engines. At the top of my list is correct balancing of all internals! (before someone asks...)
.I've got considerable oil leaking through the valve guides. So I may have to choose replacing all guides and valves while the heads are off being worked or I was thinking valve guide seals might be a way to go. But sounds like not a good idea.
