engine vibrations
jdeoliveira74
wilmington nc
So after I finished install of new Ip pump and valve cover gaskets. Truck starts up and runs perfect. Noticed the fan seemed to be hitting the fan shroud. No biggie wrong.... Today I start truck engine if running smooth but seems to have a really bad vibration. I figure the worst harmonic balancer, I check all engine mounts, transmission mounts ect. Nope so the clutch on the fan went and the shaft on the fan had moved about a quarter inch off center. Glad I caught it before if went into the radiator. Guess its just a reminder to check over your truck on the regular..
Speaking of does anybody have the part number for the transmission mount as the local parts counter has the wrong mount listed!
Warthog
240
OKC, OK
When asking for part numbers, it helps to tell us what kind of vehicle. We ( I ) don't remember things very well anymore.....lol
You can always get the GM part number from the tech manuals.
TM 9-2320-289-34P
Figure 71
Item 2 - GM 3705444 - NAPA BK 6021034
Item 4 - GM 14009321 - NAPA BK 6021035
