Extra hole on 12 bolt hmmwv wheels
HOGGIN84
Hurlburt Field, AFB Florida
Hello SS--
I have purchased 5 12-bolt Hmmwv wheels and im in the process of reworking the wheels i.e. studs/nuts and o-rings.....i have never done this before!!! I have found alot great info on this subject except for one little detail....when i got the wheels they were disassembled, so im not sure how the wheels go back together, there is an extra hole between two studs on the face of the wheel and the actual wheel itself, how does this work? Do you offset the holes or what??
Thanks in advance
ODdave
41
lansing michigan
Your missing 1 stud and the other is an alignment hole, Line them up. There are 2 different weight ratings for the 12 bolts. The ones with the hole being the higher.
