FDC fuel efficiency
russ132
Kelleys Island OH
I know that this may be a silly question... especially since a deuce is not fuel efficient to begin with.
How much does having the FDC connected affect the fuel consumption? I am familiar with the operation of the device and it seems to me that having it connected would allow less fuel through thus increasing your mileage. Does having it connected make a significant difference?
russ132
Kelleys Island OH
Sorry, I did not mean to insult any deuce. Mine is quite efficient at many things. I guess I meant fuel efficient as compared to say a Prius or some other super fuel efficient car. So no difference even on thicker fuels? Cool.
gimpyrobb
dumpsterlandingfromorbit!
27,787
774
Cincy Ohio
Russ, bypass the FDC. There is a tendency for them to leak fuel into the crank case oil. Bad for your motor if that happens. With it bypassed, you might notice different performance with different fuels, but I doubt it.
Oh yeah, I got those things, they are great. Thanks!
JasonS
199
Eastern SD
Here are some numbers:
8V92:
0.345 BSFC minimum at 1700 RPM, for an efficiency of roughly 39.8%.
0.355 BSFC at rated horsepower, for an efficiency of roughly 38.7%.
Series-60:
0.311 BSFC minimum at 1550 RPM, for an efficiency of roughly 44.2%.
0.315 BSFC at rated horsepower, for an efficiency of roughly 43.7%.
LDS-465
0.400 BSFC minimum at 2000 RPM, for an efficiency of 34%
0.430 BSFC at maximum horsepower, for an efficiency of 32%
5.9 Cummins VP44
0.334 BSFC minimum at 2000 RPM, for an efficiency of 41.2%
0.365 BSFC at maximum horsepower, for an efficiency of 37.7%
cranetruck
92
Meadows of Dan, Virginia
I think BSFC can be used for different purposes depending on what the manufacturer wants to sell, there are many variables, see plot below.
What I'm suggesting is that the multifuel may be much more efficient at less than full power conditions and afaik, manufacturers don't like to specify these numbers any longer because of the variables involved.
cranetruck
92
When you run your deuce fully loaded (cargowise), you will notice a difference in power for different type of fuels. Veggie oil/biodiesel will not give you as much power as regular diesel for example and lower EGT also.
gimpyrobb
27,787
774
Cincy Ohio
I should have said that Bjorn, I do notice my truck likes diesel the best, but it is not THAT much of a difference.
islandguydon
787
Michigan
Our local Valvoline 10 minute oil change is filling my 55 gal barrels with only their used ATF. They have a ATF vacuum to remove the fluid and install fresh. I take this and run it through a dual filter system. This for me runs better than Diesel and I pay Sam the MGR $50.00 per barrel. So that equates out to $27.50 for 55 gallons of fuel. Cant beat that with gramas stick....
gimpyrobb
27,787
774
Cincy Ohio
Good deal on the fuel. I get hydraulic oil, Wmo, gas/diesel mix, and transformer oil. I blend it all together, filter, and run it.
JasonS
199
Eastern SD
Agreed but this should hold true for other diesel engines, too.
