Five Ton to the Rescue
lafmedic1
Louisiana
Hello,
New Member here. I wish to share with you about my fire department and how we recently purchased a 5 Ton for High water use . I hope this will generate new discussion on its capabilities as a rescue vehicle and allow for there to be an ongoing thread here as we modify and repair the 5 ton in service
A few months ago we finally managed to submerge and kill our 2 1/2 Ton that we had on loan from the Forestry Service. It had been with the department for the better part of 15 years. The repair costs had been mounting on a vehicle produced in 1967 that had served well past its time. Traditionally we would use this vehicle for high water and hurricane rescues with its ability to pull trees from the road or cross high water.
We discovered that we would be able to purchase a 5 ton from the state via DOD property sales.We traveled to the depot and found several vehicles to chose from.
The truck we ended up selecting had some paint issues but was mechanically sound and had low hours . There was some grumbling between members who wanted it and some who did not. I must say the price we paid was great(not sure if I can share that here) and was well worth it . On the way back there was some confusion on tank fuel gauge selector vs actual tank selection and the engine became fuel starved. We managed to get it back the 60 or so miles by being towed about half way. The only issues found were with the winch being very stiff and requiring a lot of leverage to open.
As some of you know we had record rainfall recently. the 5 ton came in to hard use within only a few months of being purchased. I will share the flooding pictures and look forward to more discussion
Thank you
29243328842_71f85bacee_o.jpg29063987700_13fc91565b_o.jpg28730177233_cff9fe36ce_o.jpg28728213054_ee78a42e83_o.jpg29351150425_d1917af596_o.jpg
simp5782
Feo, Fuerte y Formal
9,260
Mason, TN
Sometimes those valves can get gunked up. Being that there is no filter between each tank and the valve. and there is usually always stuff at the bottom of the tanks. I tend to just stick with one tank when I am using a tractor. Just in case the tank doesn't switch with the handle.
I installed a electric pump to just pump from my passengers side tank into my main tank on my 923.
Gunzy
65
Roy, Utah
Nice. Those M930s are a little rare and to have the troop seats and cover is also rare. Nice score for you guys.
Valence
612
Davis County, UT
Gunzy is certainly right. Take care of those things, all of it is truly hard to find. You almost never see cargo covers for the dump trucks.
MWMULES
344
DESOTO, KANSAS
I hope your dept has done the post fording maintenance and with the picture of it being in water deep enough to fill the bed you are going to need it. I am pretty sure in water that deep a fording kit would be a good add on. I found out the hard way as I bought a M275 truck tractor that was used by a FD during Katrina and was assured they did all the post fording maint, it is now in a scrap yard.
fsearls92
141
International Falls, MN
That's a good looking truck! I have heard of the m930 but have never actually seen one, I was starting to think they were a mythical creature (seen plenty of m929's though).
lafmedic1
Louisiana
Thank you. We have run both tanks now that we know which lever chooses the tank. This truck came from a base direct to state depot so it did not sit long. Also has routine run and checks done before purchase
lafmedic1
Louisiana
The truck tan through friday till saturday before we lost the radiator hose but the truck never over heated. We have an on dity mechanic and He changed the diff fluid on Monday once things had calmed down. Looked like milk. We will be running the breather tubes higher and from what we understand the plug under the motor or diff was removed that can allow water in when the Snorkel was added
lafmedic1
Louisiana
There were actually 2 there. I didnt know it was rare.This one came from Florida from what we gathered. No rust on frame. Bed was full of asphalt build up. To address the other poster yes that is approx 8 ft of water on a state highway at night. As fr now we need to add a ladder. We are thinking of something similar to the LMTV set up unless someone can suggest something better. We can weld it and if someone has plans already that would be amazing
lafmedic1
Louisiana
Thats weird. There were extra tops we were offered. We decided to take off the soft cab cover and purchased a brand new in box hard top for very cheap
Jbulach
2,055
Sunman Indiana
Maybe someone local can hook you up with a new hood. There where so many surplussed that they should be worth less than repainting it.
Flyingvan911
158
Kansas City, MO
As MWMULES said post fording maintenance is huge. I would download the TM's and be sure you know every single thing that needs to be done after fording. You might even make a laminated cheat sheet since you may be fording more often than the average MV owner.
