Flat towing an M1009...should I pull the driveshaft ?
acesneights1
24
20
CT
I sold my M1009 and have to deliver it around 90 miles away . I have to flat tow it with the med duty towbar with my M1008 because I cannot get a second driver. Should I pull the rear driveshaft or can I just put the t case in neutral ?
1,827
The pump in the transfer case is driven off the rear driveshaft so you should be fine. With that said, my personal rule of thumb is anything over 50 miles, I pull the shaft. Extra layer of safety so to speak.
Tinstar
2,596
East of Edmond, Oklahoma
Didn't I read that if you do not pull the driveshaft you will cook the transfer case, except for very short distances?
Chaski
56
Burney/CA
+1 on this. The pump on an NP208 is driven by the rear output shaft. You should be fine to put the transfer case in neutral and flat tow it.
ODFever
Madness Takes Its Toll...
76
Orlando, FL
Just curious, acesneights1. Do you have a Class III hitch on your M1008? If so, can you rent a UHAUL trailer or tow dolly and load up the M1009?
