Flu419 dipper /stick cylinder gland same as case 580E?
419g
USA
Howdy having a tough time finding a gland for the FLU Dipper/Stick Cylinder anyone know if it is the same part?
Speedwoble
288
New Holland, PA
I have a spare backhoe I have been parting out, including cylinders.
I can try to look at the parts catalog to see if they are the same.
The FLU parts book says NPN-241 which is not valid in the CASE system. Looks like the 580e gland is G107524, which may sub to 1543019c1 for $460 from Case.
419g
USA
Wow thank you Speed! em that's alot $$$! Albeit a good option to have, Hopefully some of those 17 SEE out of Auction in texas will start to come online or the backhoe you are parting is a SEE?
419g
USA
Alternate part # is 1543000C1 seems to be a fairly common older case part used for swing dipper and stabilizer cylinders found one from EI for 117$! Thanks Speed!
