Flywheel
Florida9
Lantana, FL
i bought a new flywheel from advanced auto parts for my 85 chevy k30 6.2l because my old one broke now i got the new one in and the tranny is bolted and everything but the torque converter bolts don't line up and the flywheel is on right it only goes on one way i just want to make sure before i drop the transmission again that there is not some trick the bolts are off about a half inch i can put the bolt threw the flywheel and it will go above the torque converter hole
1,169
What brand and part number did they give you?
1,169
If you click on "customer reviews" on the website for that part you'll see this.
Transmission Flexplate:
will not bolt up to th400 with 11.5" bolt patern on torq converter
Florida9
Lantana, FL
yeah i just seen that but i never used there website when i bought it i just went into the store and brought them the old one so where do i get one from?
Stonepicker1
77
Coconut Creek, Florida
Florida9,
If you can't find one let me know. I have a new flexplate and a good used one.
I'm about 1 hour south of you. I could have it in West Palm Beach on Tuesday to get it closer to you.
hogtruck
Edinburg, MS
Try www.rockauto.com.
Looks like you got the flexplate for the 700R4, instead of the TH400.
The Dorman number you need is 04340 and the ATP number is Z136.
That Dorman number seems to correspond with the Advanced Auto part numbers.
1,169
Does the Hmmwv use the same flex plate?
