front axle seal
seabeeut
Conn
had a good day here in the northeast so figured I get my seal done leaking bad soaking the breaks so I alotted six hours read the TM's and members post's got started had a friend help with the tire and drum everything was going great. Then the seal retainer!!!! had my big slide hammer with me no dice banged that thing till Iam soar used my torch no luck had to rig my two jaw puller and heat the snot out of the axle and it finally popped. hard to see in the picture but the puller is bending the 3/4 inch rachet was using a two foot breaker bar to apply the force on the puller.
seabeeut
Conn
Just one side I have to work out side so I am getting the bad one done and will get the other in the spring
steve6x6x6
Winter Haven, florida
When you pull down both sides you can knock out the seal holder from the other side with a 6' long small round bar, right through the hole in the cross pin.
