front battery dieting
jwasjp
nj
I have a 1986 m1008 I had both altenators rebuilt less than a year ago. The volt meter is in the red and the front battery is dieting. Does anybody have any suggestions also I just put new battery in and it went down overnight
1958 M274
North GA
i have a 1986 m1008 i had both altenators rebuilt less than a year ago. the volt meter is in the red and the front battery is dieting. dose anybody have any suggestions also i just put new battery in and it went down overnight
Have you tried feeding the battery a highly acidic diet?
Warthog
227
OKC, OK
You have a parasitic drain somewhere. My first guess is one of you alternators.
You need to have them tested.
Also an FYI. There is a site rule that you attempt to use capitailaztion in your posts. It has become such a problem that the moderators are starting to enforce the rule. I fixed your post.
Warthog
227
OKC, OK
I would test the front alternator first. A good chance the voltage regulator or the rectifier are bad.
lavarok
33
Fellsmere, FL
What about spelling?
