Front Shackle
allenhillview
Jonesborough, TN.
Rear of front spring, is the 1/2 inch that comes in a ORD fush kit do anything to make my stock 1008 drive differently, (the extra 1/2 inch longer shackle height?)
Pinion angle is it ok with the half inch increase on the longer shackles?
Caster angle is it better or worse?
I,ll finish install tomorrow but not to late to put stock height shackle back in with oem height, all inputs welcome.
allenhillview
Jonesborough, TN.
No replies yet, hum drum!
Does anyone have idea on this? Ord kit is 1/2 inch longer on rear of front - frame to spring eye shackle height.
Ord says its fine no problem, but; does anyone have a kit on stock spring and stock height that can say for sure on drivability , does it stay the same, does it help on caster, does it hurt front pinion angle?
Someone have anything?
Thanks to above while I was writing last post.
bchesley
Whitehouse, Texas
I have the longer shackles on mine and noticed absolutely no change at all in drivability. I no longer hit the frame on big bumps compressing the spring. Hope that helps.
Brad
allenhillview
Jonesborough, TN.
All good on finished install, no issues , drives the same as before, just wanted the piece of mind new bushings, stay bar bushings as well, new gear oil front and rear.
Thanks to all who replied.
